[FS: General] JVC 15" TM-H150CGU Reference Monitor
aw grasshopper
Like so many others, I have moved on to HD so this awesome monitor is for sale for those of you still in need of one for regular SD work. I am asking $200 plus shipping for this monitor.
Here are the specs and other information I have gained from websites along with the below link that shows the slot port configuration on the back of the monitor:
Here is a link to the website talking about the monitor along with pictures of the adapters on the back of the monitor:
http://pro.jvc.com/prof/attributes/tech_desc.jsp?model_id=MDL101461&feature_id=02
The monitor has an all-metal case, is widescreen and 4:3 switchable and auto detects both PAL and NTSC systems. It also has a built-in speaker. Standard from the factory the monitor will accept composite and S-Video inputs and has an expansion slot for cards that add analog component ins and outs and digital SDI ins and outs.
Superior Resolution
The TM-H150CGU is a high resolution monitor that is more than capable of displaying its standard composite and S-video inputs. When the expansion slot is used for analog component or uncompressed SDI, the unit shows all that can be shown, adequate for almost any edit suite or production location.
Switchable Aspect Ratio
The monitor will display naturally widescreen 16:9 elements as well as conventional 4:3 video. The TM-H150CGU is ready for widescreen production.
Front Panel Operations
Changing color or other standard picture-look parameters can be accessed right from the monitor's front panel. Phase, Chroma, Brightness and Contrast control are all just a push-button away.
Remote
A D-sub 15-pin connector is built-in to provide the user with the ability to select and change aspect ratio, input source and toggle between overscan and underscan with RS-232C. (Remote not included.)
General Specifications
CRT Size
15"
Video System
NTSC, PAL (Auto Detect)
Maximum Resolution
750 Lines
Color Temperature Pre-Sets
6500K, 9300K (Selectable)
Input and Output Connectors
Composite: BNC (x2 Input, x2 Output)
S-Video: 4-Pin Mini DIN (x1 Input)
Audio: RCA (x4 Inputs, 2 each for A/B inputs, 2 output)
Remote Control: 15-Pin DSub (x1)
*Component Video: 3xBNC (x2 Input, x2 Output) 1
close
*Needs optional component board.
Set-Up Features
16:9 or 4:3 Aspect Switch, Phase, Chroma, Brightness, Contrast, Underscan, Monochrome, Blue Gun
Built-in Speaker
The monitor comes as standard with a built-in 3-1/4" (8cm) speaker delivering an output of 1W.
Remote Control
15-Pin DSub (x1)
Rack Mount
Optional (RK-C150G)
Power Requirements
120VAC, 60 Hz
220-240VAC, 50 Hz
Power Consumption
1.2A
Dimensions (WxHxD)
14.3 x 12.3 x 16.5" (3.6 x 3.1 x 4.2cm)
Weight
35.2 lbs
Monitor front small.jpgMonitor front 002 small.jpgMonitor front 003.JPGMonitor back small full.jpgMonitor back small.jpg
