I'm selling my JVC (TMH150CGU) 15" Color Production Monitor. The features and specs listed below are from www.bhphotovideo.com, where I bought the monitor from. I bought this monitor brand new, and other than opening it up, I never ended up using. The film project I was working on ended up not requiring it. It's in mint condition.
Cost: $300.00 plus shipping. Email me at michaeldecesaris@yahoo.com if you are interested. Thanks.
Features:
The TMH150CGU 15" Color Production Monitor is a very high performance broadcast monitor with 750 lines of horizontal resolution. The monitor has an all-metal case, is widescreen and 4:3 switchable and auto detects both PAL and NTSC systems. It even has a built-in speaker. Standard from the factory the monitor will accept composite and S-Video inputs. The unit also has an expansion slot for cards that add analog component ins and outs and digital SDI ins and outs.
Superior Resolution The TM-H150CGU is a very high resolution monitor that is more than capable of displaying its standard composite and S-video inputs. When the expansion slot is used for analog component or uncompressed SDI, the unit shows all that can be shown, adequate for almost any edit suite or production location. Switchable Aspect Ratio The monitor will display naturally widescreen 16:9 elements as well as conventional 4:3 video. The TM-H150CGU is ready for widescreen production. Front Panel Operations Changing color or other standard picture-look parameters can be accessed right from the monitor's front panel. Phase, Chroma, Brightness and Contrast control are all just a push-button away
Specifications
Application Broadcast, Editing, CCTV CRT Size 15" Video System NTSC, PAL (Auto Detect) Maximum Resolution 750 Lines Phosphor Not Specified By Manufacturer Color Temperature Pre-Sets 6500K, 9300K (Selectable) Input and Output Connectors Composite: BNC (x2 Input, x2 Output)
S-Video: 4-Pin Mini DIN (x1 Input)
Audio: RCA (x4 Inputs, 2 each for A/B inputs, 2 output)
Remote Control: 15-Pin DSub (x1)
*Component Video: 3xBNC (x2 Input, x2 Output) 1 close
*Needs optional component board.
Set-Up Features 16:9/4:3 Aspect Switch, Phase, Chroma, Brightness, Contrast, Underscan, Monochrome, Blue Gun Remote Control 15-Pin DSub (x1) Rack Mount Optional (RK-C150G) Power Requirements 120VAC, 60 Hz
220-240VAC, 50 Hz Power Consumption 1.2A Dimensions (WxHxD) 14.3 x 12.3 x 16.5" (3.6 x 3.1 x 4.2cm) Weight 35.2 lbs (16kg)
Features:
Specifications
