Well, I just picked up a (very) used DVX100A off craiglist today. This thing is a beater.
500 hours, and it was dropped causing a fair bit of damage. The filter threads/lens hood assembly broke off, causing the focus ring to fall out too. Top handle was broken off and reattached. The top mic fell off too, but interestingly still works fine. LCD doesn't work at all. Other than that , she's great
Used A's seem to go for $1,000 to $1,200 around here, so I offered $200 for it and he took it. Not sure if I overpaid, but it still records and came with three batteries, a UV filter and a replacement handle. I figure a parts camera would probably cost $200 so any use I get out of it is a bonus.
I taped the mic on until I can figure out a better method to reattach it. Glued the filter ring back on with the best epoxy I had around, manual focus works although the ring feels a little loose - not sure if this is normal or not. The handle seems secure enough so I'll leave it for now. We'll see how long it holds together, but I am excited to try it out.
