[FS: General] Joystick COntrolled Pan & Tilt System
7DDude
Joystick-Controlled Pan and Tilt System
Simultaneous 720° Pan & 360° Tilt
For Cameras up to 13 lb.
Attaches to Tripod or Any 1/4" Thread
12' RCA Cable Included
You can use regular AC Power or the system can also be powered via an optional Wild Shot Camera CPT 1020 battery. The battery connects to the joystick and the joystick connects to the main assembly by an included 12 ft RCA cable. (The battery is a 12V 1.2Ah lead acid battery and comes with a 750mA wall charger.) This system is very quiet also.
This unit has only been used 2 times and is in 10+ condition, and works flawlessly! I'm down sizing some of my gear and going on an extended road trip for a Video & Camera Shoot. It sell s for $840.00 At B&H Photo/Video. This is a steal at $500.00
I have a fair amount of transactions at Fred Miranda, under dblight.
Photos can be sent.
Pan & Tilt System with added photos
BatteryCharger.jpgIMG_226946.jpgIMG_226951.jpgIMG_227252.jpgIMG_227253.jpgPan&Tilt Head.jpg
Does the unit come with the battery?
No it does not. I stated that the battery is (Otional) I also give the Specs so anyone can put there own battery system together, it's real easy and way cheaper than buying the Wild-Shot battery setup, from B&H,
See this link for the battery you need, http://www.ebay.com/itm/12V-9AH-Sea...US_Rechargeable_Batteries&hash=item1c31ff84bc You can get the charger and the alligator leads from any Radio-Shack or a Batteries+ store or I'm sure on line, I don't think the whole battery setup could cost more than $35.00. Hope this helps clarify things.
