I beg for your indulgence; I am shooting 1080 24p with my GH1
1) in the input section of jes , do I have to check 'reinterlace chroma' and why?
2) in the project section , do I check reinterlace chroma after inverse telecine? why?
3) in FCP log and transfer preference pane do I check remove advance pulldown and Duplicate frames?
4) when I use my other camera GF1 which is is max 720p and I use the pull down thru Jes it says ' error cannot detect Cadence', does that mean there is no pull down with 720p? why?
5) if I mix my 1080 24p deinterlaced clips from my GH1 and the non deinterlaced clips from my GF1 which I I assume is 60p in the FCP time line, would that be a problem?
Can I set the 720p in the sequence setting to adapt a 1080 24p ?
Thanks again for your patience.......:cheesy:
