The closest cinema that runs regular first-run movies with a digital projector is 2.5 hours away from me. By Jet.
- Mikko
Gross Alaska Theatres is getting a makeover in a big way: new sound, new projectors, even a few extra dimensions.
Gross Alaska is going completely digital in both of its Juneau theaters plus its Ketchikan Coliseum Theatre. All theater screens are undergoing construction to outfit digital picture and sound technologies.
Utilizing digital technology will also bring 3-D movies into Southeast Alaska with one 3-D compatible screen in Glacier Cinemas and another in the Ketchikan Coliseum Theatre.
The sound upgrades will include Dolby Digital 5.1 surround sound systems in each theatre. One top of that, one screen in each will feature a 7.1 surround sound system, completion of which is scheduled for the summer.
Hz = Hertz = The SI unit of frequency in cycles per second.
1Hz = 1 time per second; 2Hz = 2 times per second; 24Hz = 24 times per second.
Film traveling through a projector doesn't run smoothly (at the point of projection) but rather is jerked through by a mechanism that's synchronized to the shutter.
The film is advanced a frame set into position for projection. Then the shutter opens to project the image onto the screen. The shutter then closes, and then the film is advanced to the next frame. Many systems open (and close) the shutter twice (or more as noted above) before each frame is projected to increase the image projection frequency (measure in Hz).
A projector showing 24fps film at 48Hz (a common standard) shows the viewer 48 images - enough to reduce flicker, which contain 24 frames which is enough to provide for the illusion of motion.
Film runs smoothly through the other parts of a projector, obviously it's less stressful on the film and the projector to keep a constant speed; but the film must also be running smoothly for the audio track (either an optical audio track on the film; or a synchronization track for external audio equipment).
- Mikko
Does sitting in the dark count as a frame? Is film 48 fps played back with every-other frame, a non-frame? That is a strange way to look at it.
So let me throw this question out there.
Lets say 48p and 60p do take off. Would a project shot today hold up better 5 years from now if it was shot 1080p 24p or 720p 60p/50p? Sure 720p may not be as detailed but the temporal resolution is there. Which form of resolution is an audience going to care more about five years down the road?
Audiences have been rejecting 50 and 60 motion changes per second for years as cheap and 'soap opera' looking and my bet is the hobbit is going to look like a cool 3D play / live video game, not a movie. It will be neat, but I doubt it is the 'future of film' or the 'future of movies' I should say.
Actually 60i is not quite the same as 60p. NTSC video is interlaced, so it's half the image for 30 seconds, then other half for another 30, which creates a different motion signature than true 60p because movement gets split between the interlaced frames. Saying it will look like a soap opera is not actually true. It will look different, but it's not going to look like Days of Our Lives or even that 120hz crap on new tvs. Cameron is pushing it because 24p is problematic for 3D content. Jackson is shooting 48 because it downconverts easily to 24p, which is the rate it will still show in 2D theaters.
24 just seems like the sweet spot. It feels like the norm for un-reality or suspended disbelief. 60 being more realistic looking, as Cameron says fits better with documentaries, news ect. 48 is an interesting look. I always liked the look of HVX footage played at 100 at 48fps, seems like a good middle ground very different than 24 but not as realistic as 60.
I think for dramas you run into the issue that you almost have to much detail at 60, art is not supposed to be squeaky clean. It should be ruff around the edges.
Wouldn't that be nice? 48p is going to need complex conversion for both 50 hz and 60 hz standards.
