jaggies when panning
Re: jaggies when panning
That looks really compressed. Did you do any recompression on this clip? To answer your question, no the dvx footage is not supposed to look like this. If this is a file directly from the quickstreamDV you need to check your settings.
scharky, did you save to your hard disk and view the footage? the one at the link is smaller. i did not compress the footage. it is actual footage from the dvx, 720x480.
Yeah, I save it to my desktop and opened it in the quicktime player, at 100% it looks rather blockey and compressed. It looks like when you import a dv-avi file and then recompress it to a quicktime dv-ntsc file.
watching john's double clutch music video, there are no jaggies(horizontal lines) as the camera swish pans, etc. this tells me there is something i need to do in my settings to avoid this. i played w/ the detail level w/ no luck. any suggestions? thanks!
Boo
I cannot see what you are talking about! IS this an issue with DETAIL LEVEL perhaps? :-/
try saving the clip to your hard drive that way you'll see the full 720x480 resolution. if you go to the last frame of the clip, you can see the lines especially on the plant's leaves.
[quote author=boo link=board=Events;num=1079490225;start=0#0 date=03/16/04 at 18:23:45]can someone check if these jaggies/interlaced looking lines are normal on the dvx?  especially noticeable when panning.  is there a way to lessen it?  thanks!
http://homepage.mac.com/joeboo/iMovieTheater3.html[/quote]
Boo, are you looking at this clip in Quicktime with the High Quality setting on? By default it is usually off. The panning issue, is different. Shooting at 24p is going to look strobe-like. If you're taking about the slight jerkiness to the motion, it may be because you have the stabilizer turned on.
I did see a ZIG in the leaves but....
Again, is this a detail issue? I mean it didnt look completely wacked out.
i set the quicktime quality to high and that made it look better...however, in fcp4, the video still has those jaggies as you can notice on the leaves. do you guys think its a detail level issue? i'll played around w/ the camera a lil more...appreciate your comments! thanks!
Thats the only thing coming to mind in that Im just not seeing, I think, what youre talking about?
Do you know if used Default Settings or did you tweak like a maniac in camera settings?
did a little tweaking...close to default... john, do you remember your settings for your music video? thanks...
[quote author=Bob Gundu link=board=Events;num=1079490225;start=0#11 date=03/17/04 at 16:50:10]
Boo, are you looking at this clip in Quicktime  with the High Quality setting on? By default it is usually off. [/quote]
Ok, now I'm really confused. when I look at this clip, downloaded to my hardrive, it looks as compressed as a poorly converted mpeg1. What am I seeing here how do I change the quicktime settings to high, and why do other quicktime files play fine. here is a framegrab just so you can tell me if I'm going crazy or not. Boo keeps telling me that the clip is not compressed, so exported a short clip in quicktime dv format from a recent short I did with the dvx. I'm really confused here, is quicktime not playing back boos clip at full resolution?
here is the link
http://www.stefweb.net/screen.jpg
I think that might be it. Wow. What a contrast in images. Now, I see exactly what Boo is referring to.
Love your wallpaper BTW.
scharky, these are the files directly from the dvx captured in fcp4. i just tried marjamar's settings and still getting the same results... ??? i never had this problem w/ my vx1000...i'm still getting to learn the dvx and trying my darndest everyday and keep referring to the manual as well as steve mullen's guide w/ no luck...guess i'll keep on trying and will continue to listen to suggestions...
