Barely used. The only thing wrong with this set up, is the padding on the shoulder mount is coming off a little bit. I think the adhesive got too hot, so it probably just needs to be re-applied or a strip of gaff tape would do the trick. I'm also including the JAG baseplate set up. This way you can mount your tripod plate to the rig and quickly run and gun if needed. It has the upgraded 8" zacuto rods and I also have an extra set of the Jag rods in case you want to modify the rig. Two universal lens gears included and a railblock to mount a Zoom or anything of the sort. Price dropped to $260. Sorry for the cell phone pic, the 7D is off getting professionally cleaned.
Headover to Jag35.com for better specs and photos.
