The original post noted liking certain features such as time code in/out and Log mode. May I suggest you take a look at the Panasonic EVA1. It has TC I/O, RAW out & proper audio connectivity without the need of an accessory back. It can also output 10-bit 422 4K video over both SDI & HDMI, captures 14-stops of dynamic range, runs on small batteries instead bulky Gold- or V-mount bricks (there are 3rd party versions with a P-Tap if you need), records robust codecs onto petite SDXC cards, and offers an image that everyone seems to love. Plus the camera body weighs just 2.65 pounds. The EVA1 has been approved by Netflix for original productions, which is a pretty big deal.
OK, enough of my pushing here. I’m the Product Manager so I’m kinda partial. But it does sound that based on your statements the EVA1 may be of interest to you.
Well surely logic would dictate that if you have 18-35 in one lens and 50-100 in another.. you would be changing lenses alot less than a box full of primes .. ?
Re the shot list.. I would shoot all the shots needed on the one lens and then all the others that needed on the longer .. one change.. they dont have to shoot in order.. just tick off the ones you have done.. when your talking about a controlled shoot.. ie do the 18-35mm ones first.. then your close ups.. as per your shot list..
That logic breaks when you shoot actuality..
Consider a chef, or a team doiing an operation.
You enter and establish the space - the whole room to orientate the viewer(18, acutally ideally 16)
Then you come in on your core subject.. lets say chef chopping.
you would typically show him/her (ill call him him for simplicity) in a hands to head mid (35)
then you would bash in on his face of concentration (70)
and then show what he is concentrating on chopping carrots (70)
He then statrs chopping cucumber So you revisit the mid face and cucumber (35)
Then bash in on face (70)
and cucumber slices (70)
He then moves to steak - so you go to him and steak (35)
then face (70)
and steak and knife (70)
Then.. bla
Because your 18 shot was far enoug back, you can still cut back to it during carrots cucumber or steak.
Chef and carrots, surgeon and patient, tatoo artist and arm, graphic designer and computer.. they are all the same to film; wide, then mid cu cu, mid cu cu as the process develops.
(and some OTS too - probably 35)
So the wrong zooms have as many swaps as primes, 16 prime and a 35-70 needs a load less lens swaps than an 18-35 and 50-100 because the 35 and the 70 are not on the same lens.
As for $|10k being cheap - speed booster, 20 prime, 35-70 or 35-135 + speed booster will cost 1/5 of that and may be more useful.
Given $10k for lenses id spend on 18-80 or 18-110 (canon or sony) and blow the rest on a booster and cheap used primes.
I second all what you listed Mitch![]()
but after you have attached a proper viewfinder and a CORE battery with d-tap out it isn't that small and lightweight anymore.
I'm not going to argue your various points other than to take a bit of exception to this one. I'm holding in my hand an EVA1 with a Gratical Eye and a CoreSWX battery and it's still a pretty slim & trim setup. A Wooden Camera modified BMD EVF is even more petite. You can go big or small with the way you mount your eyepiece but if you keep it simple then the kit will still be a lot smaller & lighter than an FS7.
Hmm
A DP is (to me) a director of the camera and lighting departments on a film set or structured commercial.
Mainly the FS7 and EVA are not used by DPs but by solo shooters capturing actuality, or mildly structured actuality (not many chefs in a resturaunt promo will prep you 10 steaks for you to direct a cooking sequence like you might get on a feature)
I would also suggest we are often shooting sequencial cuttable coverage (wide, mid, CU, noddy, Non synch wide, OTS etc) - stuff that a trained editor can use to make a film that cuts to the duration of the VO.
The Eva is to me an appealing camera.. but it has to be purchased with the (not that cheap) Canon 18-80 otherwise it is basically a non starter for this type of work - which is a shame considerinng that is is conserably lighter than the FS7
I feel there is a huge lack of zoom options in the S35 solo shooting class.
Mass being the topic of this thread![]()
... The Eva is to me an appealing camera.. but it has to be purchased with the (not that cheap) Canon 18-80 otherwise it is basically a non starter for this type of work - which is a shame considerinng that is is conserably lighter than the FS7
Anything with 10bit log would be great.
T Anything with 10bit log would be great.
it exists, it's called GH5/GH5s
I acquired it as B-cam because I was sick of the rolling shutter of my a6300.
The color science was so convincing that I ended at the EVA-1
LOG with custom white balance is priceless.
