philiplipetz
Here are the symptoms of "codec problems" the GH1:
1. IQ suffers when image becomes complex
2. Movement degrades IQ
3. At least one report that audio suffers when IQ suffers
4. Lowering resolution to 720p from 1080p improves IQ
5. IQ suffers when using m4/3 lenses that trigger onboard distortion correction
6. Kit lens IQ is much better in still tests than in video tests
7. Panasonic AVCHD implementation at 13mbps in other cameras can be better than 17mbps in GH1
8. Several informal reports that AVCHD data rate drops when presented with kit lens and complex images
Panasonic knows how to make good AVCHD codecs, what is happening is that the onboard computer is insufficient to handle all the tasks that are thrown at it, and so it is programed to DELIBERATELY reduce the AVCHD quality when it is stressed. This allows it to put out something. Unless it reduced IQ there would be dropped frames when the computer fell behind.
If this is true then requests for a firmware upgrade are futile unless you are willing to forgo one of the automatic features. However, dpreview shows that the kit lens is not very good when tested on a camera without internal distortion correction, a camera without the onboard computer. This suggests that the Panasonic cannot turn off lens correction to improve IQ, AVCHD will improve but lens performance will suffer. Clearly, Panasonic is committed to onboard lens distortion correction so they cannot retreat from that path.
It appears that the lens team presented the computer team with a lens that required more correction than the computer team had allocated. They had to ship and the result was deliberately degrading the image at times.
Still I am seriously considering purchasing a GH1 and using only my FD lenses, but I will await the GH2 eagerly. The only firmware upgrade that may work is if they somehow figure out a way to use the onboard computer chips more efficiently. Not easy to do. I really hope I am wrong as I want a miraculous solution.
