slipstrea808
So for some reason all my clips are being imported into Resolve with a 60fps project base. So when the timeline is set to a 23.98 time base, when you count the time it takes for the timeline to get to 60fps and one second has gone by... you have counted actually two and a half seconds in reality. The clips are supposed to be played back at 24fps but for some reason Resolve "sees" them as 60fps. When you go into the individual clip folders there is a file with information about the clips themselves. Is this file from the 7Q or is it from Resolve? It does have two mentions of framerates. One is 23.98 (or some clips it says 239.8???). The other part has "project" in front of it and it reads 60fps. Changing it seems to do nothing. Resolve is reading off that part of the file that says "project 60fps".
The solution at the moment is to right click the clip in Resolve and adjust the clip's framerate to 23.98. It works but I would like to find where this issue is coming from. It is not reflected when importing clips into Speedgrade or After Effects. I have to figure out if it is me or if it is the 7Q or Resolve.
I'm pretty sure I'm missing something obvious. Thanks guys! :thumbsup:
