With an external recorder. The AF100 has both HDMI and SDI outs.Is there any way to record 1080p / 30, 25, and 24 externally?
Maybe and yes.
It records all the formats you've mentioned.
It is worth getting if you can use it to produce media at a profit. Considering its low cost and ability to work exceptionally fast and fuss-free, it can easily pay for itself in a job or two at typical video production rates.
There's nothing proprietary about the AF100's outputs. It outputs industry-standard signals. Any recorder that supports HD-SDI and/or HDMI should be able to properly receive and record it.Thanks. I'm basically looking for which recorders support Panasonic's 1080/24PsF to take advantage of the uncompressed 8-bit 4:2:2 feed. Looks like it might only be Panasonic proprietary recorders using the AVC-Ultra codecs. Can anyone confirm this? I just want to take advantage of the uncompressed out feed via HD-SDI cable.
I would wait and get blackmagic video assist.
There is no 1080/60p out, no. That can't be done on HD-SDI. But the AF100 has always been able to output 1080/24PsF and 1080/30PsF over its SDI port.Thanks Barry. I ask because back in 2011 I shot with a NanoFlash receiving the SDI feed, and the AF100 at the time (with the earliest firmware) could only output a 720p/50 signal. There was no 1080p out in that year.
HDMI has always been 100% uncompressed, just as the SDI is. And HDMI is the only way to get 1080/60p out.Panasonic's specs states that uncompressed out is only via SDI, not HDMI.
The AF100A adds an ability to output 10-bit (although it's synthesized from the internal 8-bit processing).
There's absolutly no reason to record externally from the AF100 unless you need Prores or DNxHD because the image quality wont be any better than the internal recording.
I've used the AF100 and compared internal vs external recording and it's the internal processing that limits the quality. You wont gain anything by recording externally. The image is on par with a Canon 5D mkIII when it comes to detail with the difference that the AF100 smears more. Expect to see 1080 recordings to resolve about 720p.
Wait you're saying the AF100 AVCHD 2.0 is the same as the FS100 quality codec where people said you didn't need an external recorder?
I humbly suggest the excellent Odyssey7, which will record the 108024psf signal from the AF100 and also sports an excellent OLED monitor. It has exposure tools and focus tools that greatly enhance its use as a monitor over more basic recorders. I am a bit partial as I work for the manufacturer, but there's lots of info online.
