Is there a Componet to DVI converter?
bena
DVXuser Sponsor
If I want to use a DVI monitor, like my Dell 20 inch, which unfortunetly does not have Component inputs like the 24 incher, with the HVX200, is there a box that will convert the signal to DVI?
How much res will the Svideo port put out?
kidzed said:
if it has 15pin VGA then an analog component to VGA should work. (it did in my instance of component DVD to DLP projector's 15pin VGA)
Actually no...this won't work for hooking up the HVX to a standard LCD monitor. It only worked for the projector because many projectors can switch between RGB and Y/ B-Y/R-Y signals. They simply use the same VGA connector to save space on the connector panel. You then needed this adapter cable to use the component option. But most LCD computer monitors don't have this same feature -- they're RGB only.
