Robert_Niemann
What will be the resolution of the lens? Will it be HD?
taubkin said:I'm very curious about this too, especially after seeing some material from the Z1 on the big screen and realizing Sony Lenses are NOT HD.
MovieSwede said:Do you really need better glas than the CCDs if you use pixelshift.
Even if they are not aligned it shouldnt stop the light from hitting the CCD sensors. They are still as big as if they were perfectly aligned. The lens resolving resolution will not be pixelated.
If you look at the DVX mod it clearly shows that you can get higher res picture with SD lens on the DVX.
Graeme_Nattress said:They're all HD, just bad HD.
Graeme
