smpproductions
I had a workshop today on the XDCAM HD and they mentioned that the HVX didn't shoot in true 1080i and actually uprezzes to 1080i, is this true?
smpproductions said:All I want to know is, whatever the process the HVX uses is it better or worse than what the F900 or the F350 does?
Mediacre said:OK, forgive my ignorance, but if the chips are not the native resolution that they are supposed to reproduce, what's the difference? It's technically "uprezzing" no matter what. It's making up resolution that is not there, one way or another. So what am I missing?
You're missing an understanding of how CCD "pixels" get translated into image pixels. There's no one-to-one correlation. A CCD isn't a digital device, it's analog. It outputs an analog signal, like a microphone does; that analog signal gets sampled into digital pixels, like an audio A-to-D does (and yet nobody ever asks if a microphone is "16 bits" or "24 bits" or whatever, right?)Mediacre said:So what am I missing?
Are you concerned about the process? Or the results?smpproductions said:All I want to know is, whatever the process the HVX uses is it better or worse than what the F900 or the F350 does?
Barry_Green said:In the meantime, just look at the images. Listen to the testimonials. The system works, and delivers a true high-def image that intercuts nicely with other camera systems, whether VariCam or F900.
Well, comparison in that you're not going to get a 4.5k 4:4:4 image out of it, that's true. But you do get absolutely stunning full-color images that obliterate anything else on the market. So again, yes, you could claim that the Red has "only" 1920x1080 res in the red & blue, so pixel-counters could argue that it's "no more than 1080p" but once you look at the footage it's obvious that it's startlingly higher def than 1080p. Red starts with about a 4.5k image, so even though some res is lost in the de-bayer process the end result is still an extremely detailed, extraordinarily high-def picture.Mediacre said:I would think the same comparison could be drawn with RED since it also use a Bayer sensor?
I've shot extensively with all of them as well, and it's clear to me that the HD100 doesn't make sharper images, they are at best very comparable.I have shot with the HVX200, Z1 and HD100 and it's clear that the HD100 makes sharper images.
Pixel shift isn't necessary "the same", it's just another means to get a similar result. And the HD100 isn't sharper. I mean, it is if you're comparing 720 to 720, but that's because the DVCPRO-HD recording format prefilters the 1280-pixel-wide lines down to 960 for recording. If you're comparing the live images, they are extremely comparable. If you're trying to get the sharpest images out, the HVX makes sharper images in 1080 than it does in 720; if you downrez its 1080 down to 720 you'll find that the images are every bit as sharp and perhaps sharper than the HD100.If pixel shift is the same as having native resolution because it's not a 1 pixel = 1 pixel ratio and the HVX shoots all in 1920x1080 why is that the HD100 is sharper?
For an equivalent price point a fixed lens will beat an interchangeable one all day long, any day of the week. The HVXs lens is substantially superior to that Fujinon.I don't believe it’s the lens because that 16x fuji stinks. OK the HVX has a fixed lens but still, I don't think it can be worse than the fuji 16x
Depends on what you mean by "way down". Did you turn it to "off"? There's a massive difference between "MIN" and "OFF", even at "MIN" it's very highly edge enhanced; the difference becomes obvious when you set it to "off"; you can see just how much edge enhancement is being applied when you toggle between "MIN" and "OFF". I mean, if by "way down" you mean you turned it down to, say, -6... be aware that at -6 the JVC is applying as much edge enhancement as the HVX does when it's at full maximum +7! The HD100 is extremely oversharpened.I don't think it's because the HD100 has too much image enhancement either as last time I did a test I shot with the HD100 way down in sharpness and it still came out sharper.
The HPX500 uses it, and the FX1 and Z1 use it, and the XHA1 uses it and the XLH1 uses it... what camera are you thinking of that *doesn't* use it? Only the HD100, as far as I know. Granted the HVX does it more aggressively than the others because the HVX (and HPX500) use it vertically as well as horizontally, but basically every camera on the market is using it to increase their horizontal resolution. Even the $27,000 HPX2000 uses it to get its 1080 image. It's a far more widespread and common technique than most people seem to realize.I think if pixel shift was really that magic of a thing more expensive cameras would be using it at the same level of the HVX and using a cheaper lower rez chip and making more profit. But they are more expensive for a reason right?
There are a number of distinct differences between a "pixel shift" system and a bayer pattern.Barry_Green said:To take matters further, the "pixel shift" system isn't really all that different than a bayer pattern system. Look at the Silicon Imaging SI-2K chip -- that's a 1920x1080 chip system, right? So is it "true" 1920x1080? Well, it has a bayer filter over it, which means that 1/4 of its pixels are covered with blue, 1/4 of them are covered with red, and 1/2 are covered with green. And that means that its red and blue resolutions are (guess what): 960 x 540. Its green is better, at 960x1080-ish ...................
