Is the EX1 TRUE 1080 P Progressive or not?
Yes, the EX1 is true 1080p progressive. Not only that, it's one of the few that are a full 1920x1080 on the chip.
Where did you read that it wasn't?
It does both 1080p and 1080i. The real deal.
I think Phil will confirm that - I think that's just incomplete info on the site.
yes it really does both, i have the EX1 as well and it can both... 1080p25/24/30
and 1080i50/60...
Yes, the EX1 is full progressive. The F350 isn't; it scans from interlaced chips and drops to half resolution when you speed up the frame rate past 30fps. The EX1 doesn't, it uses a progressive chipset and scans progressive at all times.
To be considered full high definition 1080 progressive wouldn't the camera have to have the capability to shoot in this format at 60 frames per second ? If the camera does not have this capability then it has no higher resolution than its 720p shooting mode.
