I'm using the Tamron 28-75. It seems sharp, but there is a strange "image shift" when I rack focus somtimes.
I actually bought this camera because a client hired me to shoot a wedding and they wanted a Blu ray deliverable. It worked just great!
I have also shot some sports with it which worked well. If you want to use it in a run and gun type shoot, you will probably want to buy
the kit lens. The kit lens is slow, but has auto focus and auto iris. The manual iris wheel also works smoothly with no clicks or 'steps'
in the iris, so you can 'ride' the iris without the audience knowing it. It's a nice combination for this type of shooting. There are a
couple issues however. The first thing, is that this is a 'slow' lens. This isn't much of a problem in shooting low light though....
this super 35 chip is so sensitive that you will need ND outdoors anyways (more on this in a sec). The gain is REALLY clean as well,
so you can gain up and shoot in low light and it actually still looks really good, even with +18 or +21 of gain. You can go all the
way up to +30 and even there it isn't nearly as bad as I was thinking it would be, just a really clean looking image even at high
gain levels. The biggest issue here, is that you may not get the shallow depth of field you are thinking you will get, as you will
need a faster lens for that. Still, at the longer focal lengths, you do get some pretty shallow depth of field, so it's a compromise
obviously....kind of like the lens itself....kind of 'good' overall but not 'GREAT' at anything. The second issue is the ND. You WILL
need some ND for shooting outdoors. If you have the money, I will tell you right now, buy the Heliopan variable ND filter. It is absolutely
awesome! Put it on the kit lens, and you now have a absolutely GREAT run and gun camera. The biggest issue here is the cost, the Heliopan
costs about $400. However, I will tell you, it is worth every single penny. It does NOT have a clear pass through either, you are getting
ND 0.3 - ND 2.0. In other words, from 1 to 6.6 stops of ND. If you are outdoors, you will ALWAYS want to have the ND on, as it will be needed.
If you are indoors, you may run into situations with the slow kit lens where you wish it wasn't on. You either have to screw it off, or increase
the (very clean) gain. It is a compromise like many things about this camera. You may want to look at the AF-100 as it has built in ND's.
I bought this camera because of the absolutely STUNNING images it puts out. But it has more 'issues/workarounds' than the AF-100. However,
I knew this going in, and was prepared/willing to deal with them....because I liked the image a bit better than the image from the AF-100.
That being said, the AF-100 looks really good as well, and you don't have to deal with external ND. I do think the Sony kit lens is better
than anything offered for the AF 100 for run and gun, as it 'talks' with the camera and works really well. Neither one of these cameras is
'great' for run and gun, in the same way something like the EX-1 or HMC-150 would be. But you can make them work, just have to know going
in what the issues might be. With the FS-100, the kit lens, and the Heliopan variable ND, you have a pretty good camera for doing
'quick & dirty' shooting where you don't have time to script and set up everything.
more like my head... my head... it reads blah blah blah blah... :grin:My eyes.... my eyes....
you can slap on a small simple prime when you have a moment for some bokeh porn
try the kit lens in manual mode and keep a finger near the AF button
Sorry, I was just joking. Please come back!Sorry. I'll refrain from making any more posts on this forum as they are apparently pretty boring.
The Sony lens gives you Image Stabilisation and Autofocus, but I found the AF too slow and inaccurate, AND there's no manual override. The lens actuation has a latency to it, as does the zoom. The f-stop of the lens, even 'wide' open, brings it inline with 2/3" chips and even 1/2" chips if you judge harshly. I did side by sides with the EX1 and FS100 to check this out.
