Hi, if you are editing your gh1 (or other HD camera) footage that you captured with the adobe rgb setting (and using the 32 bit color editing in vegas), and you are not going to dvd tv but rather to the web or blueray to be viewed on a 32bit monitor or 10 bit lcd hdtv, can't you be open (if you wanted to) to stretch a wider spectrum that is above the 0-100 levels in your rgb parade? Ie do you really need to keep everything between 0-100 still (if not going to tv) since these modern types of viewing outputs like 32bit monitors which as far as I understand have a wider spectrum than the older sd 8 bit 'video levels' tv set technology?
Isn't this also true when editing photos to be viewed on the desktop or web on a 32 bit monitor as well? since 32bit color compatible cards and lcds allow us to view a wider spectrum now than the old 'video levels' and 16bit color vga monitors.
Thank you
Thank you
