Is Neat Video worth the purchase price?
scorsesefan
I have some underexposed/grainy slog3 footage that composes about 20 minutes of a feature length doc. It's not terrible but it's bothering me. Neat Video sometimes has sales but right now it's $150 for the "pro" version. Is it a worthwhile purchase?
p.s. I have the studio version of Resolve, but I'm a). editing the doc In Premiere pro b). not well versed in Davinci.
Doesn't Premiere Pro have some sort of its own free alternative like FCP? Or did you try it and it's not good?
Waqas Qazi is the man. In this video he shows an example of adjusting an underexposed/grainy clip in Davinci Resolve with Davinci's noise reduction and then while still in Davinci, with the same clip, using Neat. Nice side-by-side comparison. You decide.
This doesn't directly answer your question, but I like to evaluate software tools based on a "time-saved" cost analysis. If $150 saves me an hour, or two hours, or three, etc. over the course of an edit, or many edits, then it's money well spent.
That being said, Resolve's built-in noise reduction is what I use on all of my projects. I haven't had a need to pony up for Neat Video myself. But usually I'm shooting my own footage that is well exposed or getting footage in-hand that looks pretty good.
If you're willing to roundtrip over to Resolve the footage you want to use NR on, then you could at least get a free look at how good of a job it might do?
Thanks, Dustin. What is your round trip process? I guess for random clips xml isn’t the best way…?
IMHO, it's worth every $$$ you spend on it. You will earn it back in no time flat on a paying job. A bit of a learning curve but once you get the hang of it you will not regret it.
Having spent years editing history documentaries with footage ranging from WWI to the current days I could not live without NEAT VIDEO. Where a lot of this footage requires intensive reworking and upscaling plus serious NR. In my experience it is by far and away the best video NR I have ever used. It's processor intensive and can be fairly slow on certain 4K material unless you have a powerful PC. Even then it's not a rocket ship render. It is available for Resolve where is where I am using it.
Chris Young
Check out:
I don't go back and forth between Premiere and Resolve myself.
I do my edits in Resolve nowadays, as I'd moved away from Premiere a few years back when Canon RAW support in Premiere was so bad. I'm not sure if they've improved it since then?
But, I'm sure it would depend on how many clips you'd need to process, as to what might be the easiest solution? You could certainly just drop a few clips into Resolve, run NR, and then re-import those noise reduced clips into Premiere to replace them in the timeline. But if you have many, many clips that might be tedious.
Yeah, I would say there’s about 2 days of shooting- approximately 20 minutes of runtime that need NR. Neat Video might be the best route. I was also looking at some reviews and it does a great job of limiting detail loss which is huge IMO.
Chris Young
Check out:
Thanks, Chris. Do you use the automatic setting? I’m wondering how you preserve the most detail and a bit of organic noise?
That's one of Neat's major appeals. NR without detail loss. I can nearly always come up with a very clean image without going soft with it.
Chris Young
Generally I draw a manual selection square in what appears to be the noisiest part of the scene in question. Very much like they show in the video I linked to. Very often that is usually in the lower light areas of the scene, the shadows up to mid-range. The thing is you can try a variety of different areas of a scene and apply it to see how it looks. You can end up with a selection that can affect your detail more than you wish. If not totally happy try another area. It's a bit of a suck it and see subjective process.
Plus remember you can select a number of areas and build a profile for the whole scene. But there again in mild noise scenarios you can just try an 'auto' selection and let Neat do the work for you. If that looks good you can go with it. The more you use it the more you begin to understand how it works which guides you to thinking "This will be fine on auto, or I will do this with manual selection." Of course, you can always hit undo and try again until you are happy.
Chris Young
Can you upload a ten-second piece somewhere? I can hit it with Neat and render it out and re-upload for you to look at if that helps. Could give an idea of whether it will work for you.
Chris Young
Resolve has a newer Ultra NR spatial tool lets you draw the box. Sometimes I like it better, other times I prefer the older tools. Ultra NR is powerful but sometimes too much for my liking. I prefer it a bit more organic as in this case. This is your file reimagined for download, I applied a CST, no color adjustments, and just simple NR. I didn't think the noise was that heavy to start with but I liked how it turned out, YMMV, be interested in knowing what you think.
Yeah, that looks real good, Tom. The detail is still there in her hair... I notice the clips come back a little shorter than their original length. Do you know why that is?
When I overlay them on the Resolve timeline, the original and the rendered copy, both are the same length, 160 frames, so no I don't know why that would be.
Here are the Resolve NR settings fyi. And for what it's worth, I *like* the way you exposed it. As an aside, what I don't like is when NR is overly strong that skin becomes waxy.
Thanks for doing this, Tom... My Resolve export settings were 24fps not 23.976 so that was the issue... Yeah, so the story is I owned the fx6 early on, sold it, missed it and bought it again right before this shoot. I guess my muscle memory isn't so great because in my mind I screwed up the exposure on this shoot day, but I guess it wasn't as terrible as I thought...
Hey Chris. I uploaded a short slog3 clip that had some heavy noise (underexposed). Thanks. https://we.tl/t-EVtwKTJ0Zy0fHcig
Thanks for the clip, Scorsese. Personally I didn't find it 'too' noisy. Was surprised it was a .MOV not as S-LOG3 clip? Was this an external record ProRes or was it a ProRes rendered from an MXF? Whatever. I've uploaded a ZIP file with two files. One processed with NEAT Video and the other one with DaVinci's Noise Reduction.
Not saying the grade is what you after but this is a typical 'look' a lot of clients seem to accept with little comment.
As the noise was reasonably simple to fix I think Resolve could process your files with little to worry about. DVR's NR is getting pretty good. And it's a quicker render out than NEAT in 99% of cases. Have a look at both files and make up your own mind. I also included two DRX files, one using NEAT the other using DaVinci's NR. You can drag them into the Gallery and then just drop on to your clips under the Color Tab. That's if you want to check the process on other clips. Obviously you would need NEAT installed for its DRX to work.
Chris Young
Download here:
https://rb.gy/y0ptha
