is my camera broken?
mungk
I noticed today that when i point my camera at a light source all the surrounding lighted areas seem to be blown out white, and i see weird scanning diagonal lines only in those white areas.
When I record though and playback in vcr the picture is fine.
any ideas?
That's the zebra pattern. There's a button to set it or turn it off. It helps to warn you when your image is over-exposed. Read the manual and Barry's book, all is revealed within.:)
aaah ok. whew. thanks for the quick heads up.
never used the zebra pattern function before and never seen what it looks like till now.
Incidently you should check the manual but the zebra patterns can be set at different ranges. I found that the zebras were a little insufficient for checking exposure. Check out the marker function which tells you your video level in a simple to understand range.
