Is it possible (pulldown observation)
DVX100percent
I recently shot some footage in 24p(advanced) mode, but then I had to mix it with another camera's footage (30i), so I had no choice other then to work in a 30i project in Avid (Xpress pro) and not go with native 24p. I was expecting to see 2:3:3:2 pulldown from the footage I shot on DVX. However what I see is 4 progressive frames followed by 1 interlaced. Which to me says that Avid (even in 30i project) interpreted the footage as 24p, removed the pulldown and then performed the pull-up (is that the technical term? :D) and added one frame for every four to make it 30 fps? If that is true it would be amazing, I don't see the reason to use 24p(not advanced) anymore.
Any comments? Please let me know if i'm missing something.
Re: Is it possible (pulldown observation)
Yes, you are missing something. WHen advancing frame by frame on the computer screen, teh source/record monitor only show 1 field or 1/2 frame. When looking at footage with pulldown, 1 field display of 2:3:2:3 or 2:3:3:2 will look like 4+1.
Michael
Michael, then how do you explain that in quicktime (which does show both fields) i see the same pattern -- 4 progressive frames followed by one interlaced?
ADVANCED cadence is only 1 interlace field per 5 frame cycle. NORMAL pulldown would should 2 interlace frames per 5 frame cycle. I was referring to the Avid source/record monitor that NORMAL and ADVANCED would look the same (4+1) when only looking at 1 field or 1/2 frame.
Michael
