It's not fiddly at all, but you need to use high performance memory cards to get the most out of the hack.
This is the memory card to get: SanDisk 64GB SDXC Memory Card Extreme Pro Class 10 UHS-I : $137 at B&H Photo
Flowmotion 2.2 is a great compromise. It's supposed to work with all class 10 cards. I shot a short film last week. Not a single crash. At one point I was shooting 3200 ISO in ETC mode, with lots of movement, filming someone on a Jetski late at night, on the 14-42 lens. Panasonic lenses, with their electronic camera communications, are supposed to be the most unstable. So that scenario was pretty challenging, but it never crashed once.
I have 32gb Sandisk Extreme Pro card.
Exposure: there's an unobstructive optional live histogram and spot meter that stay active while recording, and the GH2 also has the aforementioned flashing in the clipped portions that stays live while recording. I never really thought about it, but I've blown exposure more often on my AF100 (with all the video camera-y goodies) than I have the GH2.Also, since the GH2 has neither zebras or waveform, what is the method you use to accurately expose? I have used the 7D for example and it has a function that flashes parts of the picture that are clipping. But you can't use it in video mode so you have to snap pictures to check and even if you could it's not really helpful. How do you do with the GH2?
What about fader ND filters, which one is recommended? I heard the cheap ones cut down on sharpness.
I don't use fader ND's. I hate them. Those that I've tried ultimately soften the image, promote flaring and loss of contrast, and many introduce a color cast. When I need an ND, I go for the cheaper, better, old-school single density (+1, +4, or +8 are the usual suspects) or a polarizer.
And it doesn't affect the way the camera operates at all?
Pricey. Can almost buy a 128GB SSD.
Yep... operator error, and "eyeballing" an LCD that was set too dark to begin with.How can somebody blow exposure on a camera which has a waveform monitor for any other reason but operator error?
Generally, yes, when you have time to use them. Set the ND to compensate for ambient light and then ride the iris to expose. If conditions change often and drastically... well, life just isn't a bowl of peaches.So you think normal screw on ND filters are better than fader ones? Is that what you meant?
I designed and tested Flow Motion v2 to record and play back reliably in-camera in all GH2 video modes with standard 30MB/sec Class 10 SD cards. For extended-length recordings, 4GB file-spanning will work on all Class 10 cards in Flow Motion's 60Mbps 24L, FH , and H video modes. However, with 95MB/sec Class 10 SD cards, 4GB file-spanning will also work in Flow Motion's 100Mbps 24H, HBR, FSH, and SH modes (except for NTSC 30p HBR and FSH modes). For more details and Flow Motion v2 download info, check out this link:Flow Motion v 2.02 patch can require a memory card that reliably writes at 130 Mb/sec under all conditions which is why cards like the 64 GB SDXC Sandisk 95 MB/sec one are required. ( the 64 GB SDXC card will span when filming longer events, where the 32 GB will not )
Anyone out there trusting the hacks enough to use them for live events? I'd like to get better low light if I could, but I'm scared of a crash during someone's wedding.
DP Stewart: How do you get the "the newer Panasonic Firmware" if you don't have it? Thanks.
