Amulet Man
So, if you prefer to continue using Premiere, go to Project Settings -> General -> Video Rendering and Playback -> and chose a different "Renderer." The FCPX system you played back on is likely using Metal or OpenCL. If you have Nvidia chips that can use CUDA, just know that Apple is no longer supporting it past OSX High Sierra (so, can't use it in Mojave). Metal and OpenCL will work differently depending on your GPU, but both are alright. Just don't use "Mercury Playback Engine Software Only."
And while you're at it, you might as well go to Premiere Preferences, clear out your Media Cache, and go to "Memory" to make sure you have enough RAM allocated to Premiere.
Congrats that it's not a camera issue! Don't cut corners on SD cards! Good luck!
Thanks, this helps.
Having good luck with these:
https://www.amazon.com/dp/B07RCN2BF...pY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
Pretty affordable but seems to meet the spec and working for me.
