i've set up the iris dial to 'up open' on the day i got the camera. however, sometimes when i turn the dial up, to open, the iris closes instead.
this problem first appeared after ~ 200 hrs' use and it just gets worse by the time, until it is now very annoyingly, happens too often (but not all the time).
i remember once reading a similar report, so i wonder, if anyone else experience such a malfunction or even has a solution (which i doubt
thanks!
shai
p.s.
i'm going to reset the camera and set it up again. will let you know if it works.
thanks!
shai
p.s.
