internal mic
Re: internal mic
What do you mean by "low"? It's not really meant to pick up voices & such more than a couple of feet away.
Re: internal mic
No . . . it's better for recording ambient sound. You'll want an external shotgun mic for voices from further away than a few feet.
Re: internal mic
Well he is obviously a very intelligent individual learning with fantastic language skills and an imagination to match.
Oh well pitty we can't all be like him. :'(
Re: internal mic
Now on a serious note, have you checked that your imputs are set correctly. If they are set to line level you will get some different effects.
Re: internal mic
we set the levels all the way to the right on both channells and we still got semi-poor results w/some noise
Re: internal mic
[quote author=michael_summers link=board=Events;num=1087938726;start=0#0 date=06/22/04 at 14:12:06]my internal mic is very low, even when both channels are on their higest volume. is this normal?[/quote]
I have the same problem. The volume of the built in mic and the unidirectional model that Panasonic makes are both lower than a normal MiniDV camera. It was apparent to me the first time I watched my footage. Change the audio gain from 50db to 60db. That worked for me. I don't know why the camera ships with quiet audio.
Re: internal mic
[quote author=michael_summers link=board=Events;num=1087938726;start=0#10 date=06/22/04 at 16:08:51]we set the levels all the way to the right on both channells and we still got semi-poor results w/some noise[/quote]
Change the audio gain through the menu. That should give you better results.
Re: internal mic
[quote author=tawsy link=board=Events;num=1087938726;start=0#8 date=06/22/04 at 15:35:29]Now on a serious note, have you checked that your imputs are set correctly. If they are set to line level you will get some different effects.[/quote]
The inputs aren't a factor with the internal mic. There's no "mic" or "line" level to set with it.
Re: internal mic
Even I have low level of my audio, compar to my old camera (NV-MX300). Why? I mean shouldent there be at least the same level.
Re: internal mic
Other cameras have automatic level control, so they will boost up the volume automatically if you're in a quiet setting. The DVX doesn't have any sort of automatic level control. You have to manually control the audio levels yourself.
Re: internal mic
I find that feature on other cameras very annoying. You know when you're watching a speach on TV and when the person stops talking, the ambient noise gets real loud until the person starts talking again. Man, I'm glad the DVX isn't like that.
