Larry E McPherson
In a year of regular field use of my 250 for wildlife videos, Barry's "HPX Book," and this forum I have gained considerable respect for the camera.
For the last 3 months I have been having an intermittent noise problem that I have not been able to isolate the cause of it. In the process I have gained familiarity with just about every leaf, wind, touch, or movement of the camera will cause as well as the fine points of mounting the mic in the Rycote system to eliminate absolutely every possible vibration or cable rub.
I am using a Sennheiser MKH 8060
mounted on top of the camera inside a Rycote WS-3 full windshield and windjammer (I have replaced the cable connecting the mic to the camera with no change in results.)
I connect the mic to the camera using Input 2, set the Channel switches so that the 1 mono input signal from the mic is sent to both audio Channels of the camera, and they end up sounding and looking identical—they both either have the noise or not in an identical way.
I have sent an MP3 file of the typical noise problem to Sennheiser USA and they are going to see if it looks like any of their known issues, but haven't heard back yet.
How about the camera itself—how do I determine if the noise is being created by camera and what can I do about it?
I can email an MP3 file sample of the noise to anyone kind enough to listen to it. Is there a way I can post the MP3 with the forum post?
Suggestions, please! Thanks!
