instead of 960fps, what about 240fps FS700 footage slow to 1/4 speed in Twixtor?
Just curious about this, while I wait for my own FS700 to arrive.
Instead of shooting at 960fps natively, has anyone out there tried slowing down their 240fps footage to 1/4 speed via Twixtor???
I'd be fascinated to know what that yields. My results with Twixtor were never that good. But maybe it's because I was working with 60fps footage to start with.
If you're trying to get to 960fps, wouldn't you get much better results via Twixtor if you're starting out with natively shot 240fps???
The frame rate you start with doesn't really matter to Twixtor -- what matters is how much you slow it down, i.e. how many interpolated frames you're asking Twixtor to generate. For 1/4 speed, you're asking it to create 3 frames for every 1 in the original.
As I see it, the results you get depend on three things:
  • what you're shooting -- using a high shutter speed helps
  • how much you slow it down -- the more you slow it down, the more it has to guess, and the more warping you will see
  • how much work you put in in terms of creating masks etc (needs Twixtor Pro I think).
At 1/4 speed, I would think you could get pretty decent results with a lot of subjects. But it kind of depends.
No.. much worse with any time re-mapping tool
boundry violations, artifacts etc etc... Twixtor is cheap and pretty good.. sorta the Canon5D of time re-mapping tools, far the from the only kid on the block tho... all of them will give you grief on FG edges aginst detailed BG, means rotoing... so unless you are shooting a mountain bike against a sky with the spokes already gone from low rez camera capture...
no you are far better off getting the frame rate right in the first place
if you pick the right part of the 240fps clip, and crop after to 2:35 (border issues with twixtor) you sure can ramp to 960 with decent results. Heck, I use to take 5D 25P footage to 500fps in just the right moments of clip with fantastic results.
Just make sure when you shoot you using a fast shutter. I cant wait to try it myself with twixtor (basically an optic flow algorithm) I'll post sum results when I can.
Ha!
wait untill you have to say re-map a group of folks walking down courthouse stairs.... your time re-mappers will fail completly, even the one's in Flame, Nuke & DS - and you will be rotoing ;-)
It's easy to do a shot designed for re-mapping, and very difficualt to do a shot that has issues from the get go
So the "tests" are really fools gold... the real deal is fixing a shot to the spec's of a QC company, and trust me.. i have the been there, done that t-shirt... if it could have been shot at the finished rate, it should have been... you can buy a new FS700 and throw in in the ocean for the price of fixing a shot to meet broadcaster spec that was not an "easy" shot
So go find some folks with lose clothing, and shoot a group of them walking down stairs while dolling slowly and panning down... shoot it ona high rez camera - say FS or F3 to external recorder, Alexa, Epic... then time re-map it so they are at say 83%... when there's no more stairs wobbling, handrails shifting, clothing intersecting with faces of folks behind and above... on and on... then get a pass from Technicolor LA's QC facility... then get back to me
Or just shoot it at the frame rate needed
A "test" of a bike against a sky is worse than useless in the real world...
d
Surely the fact that your motion is already very slow at 240fps, would make it easier for Twixtor to interpolate the frames?
I agree with a caveat, where twixtor really falls apart is in dealing with motion blur, so the higher the framerate- generally speaking- the less motion blur. If people are moving fast it is still going to be there but if you pick your moments you may be able to get away with it.
I kind of agree with Dermot, and kind of disagree. For the most part, better to shoot the proper frame rate, but there are cases where you can design a shot to be used with twixtor and get away with it. I've done it shooting 48p on a Red Scarlet and passed network QC. Then when the show I was working on asked me to do another, more compilcsted sequence I told them I'd need a Phantom. And I got it. Was definitely better than twixtor. But if I hadn't hooked them with the first I never would have gotten the second.
Thank you everyone for taking the time to explain. I've already learned a lot here in this thread from everyone's input. Yes, I imagine that nothing beats shooting natively at 960fps. Like Grug, I was convinced that starting out with 240fps as opposed to only 60fps meant that Twixtor had far fewer frames to interpolate and therefore would yield much better results. Good to know now.
Regarding the Sony firmware upgrade next year that's supposed to bring 4K recording. It would be fantastic if that upgrade included a bump up from 240fps to 480fps or even all the way to 960fps at 1080p or at 720p, but I know that would put it within striking distance of the $100,000+ Phantom Flex. I know that's insane to contemplate. But I can still dream.
If you shoot at 960, you're getting a MUCH LOWER resolution compared to 240. If you're OK with that, then yes, you should certainly shoot at 960. Otherwise, I would really give Twixtor a try.
I think Dm_Rider's test looks very able to get into a wakeskatemovie, 480fps is looks pretty sharp! nice work! the blur in 960fps is already a bit too much for watching it longer than 2 or 3 seconds, but to gather attention this is also really nice...
