Ingesting 720 50p
JBP
I have a problem ingesting 720 50p from my HPX500. I have tried this on several different FCP7 machines with all updates installed. The files play perfectly in camera, in log and transfer "preview" window and in P2CMS.
I ended up capturing the shots via SDI instead. The weird thing is that it looks like it´s 25p.
Anyone with a clue...?
Most likely the problem is with FCP. When you open 'log and transfer' window, press on settings and disable the option 'remove advanced pulldown', should do the trick ;)
