Richter Video Equipment
[FONT="]I had a few questions before buying and wanted to give others more info now that I have one:
Speed:
On a fast computer it averaged 29.9 MB/s on both 16 and 32 gb cards. R or E didn't make a difference since USB seems to be the bottleneck. I will re run on my less powerful laptop without usb mouse and kb.
(Computer has I7-950, 12 gigs of ram, USB Keyboard and mouse, and a storage raid capable of 400+MB/s)
Connection:
2 usb 2.0 ports (really panny, you need 2). Even on a high powered bus both ports are required. Even worse, it is 2 separate cables, not like external hd's with 2 port on one cable. Also, the cables are white. Why would they include white cables for a black reader.
Single slot instead of dual slot:
A dual slot would be nice, but the USB seems to be the bottle neck on this. If you tried offloading 2 at once it would probably take twice as long.
Rugged:
Seems pretty solid even without the cover flap.
Driver:
Came with driver disk, but it seems it works without installing any drivers. (I will try and see if speed improves.)
Summery:
340 bucks is a lot, but its much cheaper then the 1000+ p2 readers. If recording HD, the offload time on your camera is almost as much as record time, if not more. Operational hours will go up while using the cam as a card reader. This device doesn't have a fast enough interface to make it great, although it is a good tool for reducing wear an hours on the camera. i'd recommend buying one, just don't expect it to be the best p2 solution.
-Cody
[/FONT]
Speed:
Connection:
Rugged:
Driver:
Summery:
-Cody
[/FONT]
