Interesting to see perspectives.
You mean add a little blue to his skin, or make the BG blue.. as you did?
The bright green backgrojnd is a look I went for - overheads near him were off.
It is not wrong - but you are if course free not to like it![]()
Color correction can only ever do so much if the original squinting was lit by non-continuous sources. Bad color hitting the skin will make it look more splotchy, and subsequent color correction can make it appear plastic or waxy.
I prefer the variant Nirv showed of the white-haired man, because the color contrast subconsciously improved the look of his skin. Even though the skin tone was not changed from your original shot, it actually appears more saturated and healthy due to the contrasting color.
I think the wide shots in an industrial space will always just have to fall where they fall unless you have an enormous budget and time to deal with the lighting. But closeups & interviews can be more easily controlled. I think you're on the right track with the interview shot where you lit the subject tungsten and let the background go green, however my personal preference sees that as a bit too harsh & dramatic lighting. I would prefer a larger soft source with more wrap unless the subject matter really called for this sort of look.
It's really two things: personal preference and time/money constraints. That and maybe a little makeup powder to even out their skin (it can do wonders).
The skin tones should, therefore be hittable?
S
I was referring to the fact that the keylight in the two talking heads (not the dedo one) was a northlight window with the puke lights off .. so excluding ambient reflections from the room colour the quality of the light source should have been 'good' - contrary to Mitches correct concept that filtration cannot bring back missing spectral elements.
S
