broughtonfilm
While testing the camera I noticed an odd behavior of zebras. Feels like Zebra 2 sometimes is not showing in areas where I'd expect it to show.
I did this test. Set both zebras to 94%, Zebra 1 Aperture Level is not narrow, it is set to 20 (to minimize it as a factor in how two zebras are displayed). Camera is pointed at the same target. While toggling between Zebra 1 and Zebra 2, the same exact area of the target is striped with Zebra 1 but when I switch to Zebra 2 it is not (for the test purposes you can do this back-and-forth toggling conveniently by being in Zebra Select menu). Again, both zebras are set to the same exact value. The difference is not because of narrow Zebra 1 Aperture Level setting , it is set to 20. Now, in order for Zebra 2 to show stripes in the same area of the target, its value needs to be significantly lowered (approx. 8-10 IRE on average). Of course, I see no real-life situation where both zebras would be set to the same value, this is simply to test if they are matching and seems that they are not.
EDIT: I thought that the inconsistency was caused by too high zebra setting for this particular LUT (LC709A). I performed the same test with much lower Zebra IRE settings. Both zebras are set to 74% which should be well within LC709A's IRE range. Nope, same discrepancy between two zebras, again, it is about 8-10 IRE difference.
What am I missing?
My settings:
Format: XAVC-I , 1920x1080 23.98p
Mode: Cine EI
Gamma: SLog3
Color Space: S-gamut3.Cine / SLog3
Monitor LUT
Look Profile Sel. : LC709A
SDI1 & Internal: MLUT OFF
SDI2: MLUT OFF
HDMI: MLUT OFF
Viewfinder: MLUT ON
What am I missing?
My settings:
Mode: Cine EI
Gamma: SLog3
Monitor LUT
SDI2: MLUT OFF
HDMI: MLUT OFF
Viewfinder: MLUT ON
