Incompleteness in the clip
D10S
I have some .mxf files shot with the HVX200. When I load the files into my P2CM viewer I get a red X on each thumbnail, and when I try to play the file I get an alert that says that the file won't play do to "incompleteness in the clip.
I can however play and capture those same file with the FCP log and transfer, so they seem to be fine. Why won't the P2CM viewer play them? The viewer plays other files fine, just not this batch.
You have a curious problem which is similar to mine. I have the same "incompleteness of clip" warning, but no icons to tell me that there is something wrong with the clip. At the moment I cannot transfer my footage from the P2 card either by using the camera or a Duel Adapter through my Mac.
Anybody out there that can shed some light on these problems and how to get the footage off the card?
I had that once before and had to capture RGB with an AJA Kona card because I couldn't transfer the footage off the cards. The clip played fine in camera but would not export into FCP or P2 viewer....Hope you find a easier solution...
