Upgraded EVA1 firmware yesterday to 2.02 and today started to look at the 400 Intra.
Some cards (older design without a 'V' designation on them) give an "Incompatible Card in Slot #" warning message, both when first inserted, and when recording begins.
The cards I have that give the warning are Sony G series and Toshiba Exceria Pro series.
I don't get a warning from either Angelbird (V90) or from Delkin (V60) cards.
Interestingly enough, the G series and Exceria Pro series both seem to record fine at 400I - though in addition to at initial insertion, the warning comes up each time recording begins.
I also switched the settings to dual record two cards simultaneously, which worked fine even when I mixed a "V" card with a 'non-V' card in the two slots.
At least theoretically both the Sony and Toshiba cards should be capable of faster recording speeds than the Delkin cards.
I'm guessing that the camera is either looking for a designation that it can read from the card? / or it has a reference table of cards that should be compatible.
Haven't recorded too much yet, with longest test record being ~15 minutes, but no issues yet with any of the above cards at 400I.
Would like to hear results from others..?
