Doc Bernard
Indie Arms Member
I am going to share a trick to sound treating a control/edit room for audio. This is not about isolation, but controlling bounce and nodes.
So, you have an edit room, but man does the audio bounce around and give you a false RT60 time
First.....where are your monitors? The audio kind, not video. They should be no closer than 3' to you, and a minimum 3 ft' spread to where your primary listening position is. You want to try to keep an isosceles triangle going.
So on to the treatment, There are many theories: Dead, Live, Live end/Dead end. But for a general rule, you shouldnt have to plaster the walls completely with treatment to get a good result. You just need to hit the reflection points around your room (1st order reflections).
So: My "Mirror" trick.
Materials needed: Your eyes, painter's tape, a decent size mirror, and a buddy who owes you favor.
Step 1: If your monitors are against a wall........you need pull them out away from the wall. (walls are bad, em'kay?) A foot is good. That's their new home.
Step 2: Treat the area on the wall directly behind the monitors. I use BX8's, so for me 2'x2' is good. That cuts any off-phase reflections coming from the porting.
Step 3: Get out your buddy from his box. Hand him the tape and the mirror. Sit in your listening position.
Step 4: Starting on one wall, have your buddy slide the mirror on the wall. You keep looking at the reflection in the mirror. Any time you see a monitor in the mirror, have your helper mark it with tape.
Step 5: Continue around the room, repeating step 4.
Step 6: (The Hard Part) Do the ceiling the same way.
Step 7: Now you know where treatment should go to cut those nasty primary reflections. Treat with treatment of choice, usually a 2x2 to 4x4 area is all that is needed on each "spot". And hardwood floors.......not a good thing. Put a good throw rug down.
This is in no way a solve everything solution. But it will greatly improve the sound in your standard bedroom (I mean editing bay, :grin
This does nothing for sound isolation/transmission. And only helps a little in "tuning" the room. But it will knock down any primary reflections you hear.
Next lesson: Trap that bass.
