That's like 1200 hours of XAVC 4K. What in the world do you need that for?!
Yeah, massively different. Especially if you want decent read/write speeds for editing in real-time. A place I used to work spent like $60k on fibre channel for about 5 work stations, and I think our server was only like 24TB or something.From the amount of data ended to be backed up/accessed it sounded to me like a workgroup and not a very large single user situation.
It's fairly easy to buy a very large NAS for a single users or a couple of infrequent users it's a different kettle of fish when you scale the requirements up to a workgroup situation.
I was originally looking into the QNAP's Thunderbolt solution, but decided i didn't need, it as it would just be for archiving. We were also looking at Amazon Glacier, as a whole solution, but it would have been to slow to recover if need be and scary when you here horror stories about Amazon servers going down and losing everything. We were then going to use it as a backup, but still seemed to expensive.
I'm getting in on Monday two (from Virtual Graffiti) QNAP TS-1263U-RP-4G-US $2350, with 12 x 8TB Seagate Archive drives $3096. It comes in at about 88TB in RAID5. Then we plan to use their UX-1200U-RP $1,900-$2000 expansion racks to add more space in the future. Were going to house one of the servers off site after I seed it in a colocation datacenter in our same city for about $80 a month. I'll have to report back once i've got these setup.
The system seems pretty turn key since i will be the only one using it I wanted something i wouldn't need a whole IT department for. Plus there's so many features built into these things. They even have a live demo were you can go in and mess with a server right through the web.
https://www.qnap.com/i/useng/support/con_show.php?cid=8
Are you sure those archive drives will work in RAID? I'm fairly sure they won't, they're not designed for it and the NAS will have problems with them. Perhaps these are different models to the one's i've seen. You should check that before going too far with them.
I used Glacier too, but only for project/nuke script files. Assets are just too big to transfer. So unless you've got some kind of super connection i don't think that's feasible. You pay for the speed of recovery though - for large files quickly it can really add up.
I'm not aware of any horror stories with Amazon though, the whole point is the multi region redundancy? I used both Amazon S3, Glacier and also Azure without issues.
Interesting you went for QNAP, i had both a model of that and also ReadyNAS too - dumped them for synology which i've had running for years now.
cheers
Paul
