Last couple of days I have made some measurements of GH1 audio capabilities. I've found out (like almost anybody else who have tried it) that external mike can deliver better audio quality than internal one. However, due to relatively high internal audio gain of GH1, it produces some noticeable noise. Only when input signal becomes higher than exactly 0.2mV (sinus RMS value), GH1 gradually reduces audio gain and sound improves (less noise). GH1 remains in lower audio-gain stage only if some sound higher than 0.2mV (RMS) is present at mike input. However, as soon as signal drops (less loud speech, etc.), audio gain is gradually increased back to high level.
The existing solution is to attenuate external mike signal so much that signal never (or almost never) reaches 200 microvolts value (RMS). In this case audio gain is not changing and everybody is happy. Happy? Not so much, since there is still some audio noise present in a footage due to GH1's high audio gain. Moreover, attenuating mike signal usually reduces mike's signal/noise ratio as well.
Therefore I've made a relatively simple electronics which keeps GH1 audio gain lower than usual (for about 20dB). Therefore, if you have a relatively good mike, you might get better sound. This electronics (see the picture) comes in between the mike and GH1 and does not require any internal power supply.
Attached are three measurements: Measurement with internal mike, measurement with external mike with deactivated audio conditioner and measurement with external mike with activated audio conditioner. You may hear some lower-frequency sounds which are mainly distant traffic from the highway and local roads.
External mike consists of mike capsule AKG CK91 and electronics/housing/amplifier/attenuator done by myself (I was not satisfied with original electronics from AKG).
If somebody is interested, I'll draw electric scheme, but it will take some time due to my injury (thumb was injured during drilling)
and departure to shorter vacations.
