FS7: Importing LUTs - "Access NG" issue
Hodges
I'm trying to import the ImpulZ LUTs from VisionColor into the FS7. However each time I try to import from SD card I receive a "File Access NG" error on the camera.
My file structure on the SD card is proper with: PRIVATE - SONY - PRO - CAMERA - PMWF55_F5
Any thoughts?
Make sure you're not selecting files that start with "._". These are "hidden" files that for some reason show up on the file list. Scroll down a bit on the file list until you see file names without the "._" at the beginning.
There no "hidden" files with the VisionColor ImpulZ. And I should note, I have successfully loaded other LUTs just not the ones from VisionColor. Appreciate the response though Josh.
Hi, just wondering if you resolved this? Hiring out the fs7 shortly and was planning to use the VisionColor Luts for onboard monitoring.
It might not be the issue you're having but I found the hidden files write themselves if you transfer from a mac as opposed to PC.
