Tunnell Mill
Need to input some audio via a standard Red/White cord into the Red/White audio inputs on the side of the HVX. This worked fine when I did it with my XL2 (before I sold it) but I'm having a hard time getting any levels to show up by way of Red/White on the HVX. I've played around with the settings after doing a general attempt by putting the HVX in VCR mode and hitting record, which did not work. On the XL2, I had to be in camera mode to do this and it was a matter of switching the audio input buttons. This could not be done in VCR mode on the XL2, only in camera mode. Does not seem to be the case with the HVX - I've switched the settings just about every way I know possible in BOTH modes and still nothing. I thought that perhaps I needed to use the Audio Dub mode - but can't seem to get audio to input that way, either. You'd think that having the HVX in camera mode...all you would have to do is switch the Audio Inputs beneath the flip-out LCD - doesn't seem to be the case. The camera acknowledges the XLR inputs just fine. Any suggestions would be greatly helpful. For composing music, this was a very handy way of doing things directly to MiniDV with the XL2.
