I havent had any issues since i had a new hardrive installed into my powerbook laptop from my earlier problems. But reading these new posts are beginning to freak me out. My workflow has been p2 genie to offload to a folder on my desktop and then ingest into final cut pro. I would be devistated if i encountered problems again. So i ask this from a past post.
try using disk utility to store your P2 files... your workflow seems flawed.. It's best to use disk utility to make a clone of the P2 card instead of dragging the files to a hard drive (files can become corrupted that way because they are FAT32 on the card, and NTFS on your mac desktop)... Put the p2 card into your laptop.. Then open disk utility.. Click on the Mashi*sa P2 Card and then click new image... Make the settings to read only and make sure there is no compression... Then Click OK to make the disk image... Eject the P2 Card... Then Mount the disk image clone from whereever you saved it and try and ingest from there
is this more reliable then my workflow of doings things?
