I'm new
Gpusher1
Yes, I'm new to the forum, new to the dvx100b... If there anyone with any helpful hints please feel free to help...
Thank you
Best tip I can give you is just spend alot of time on this forum and read alot of post, even if it has nothing to do with you. This site is loaded with information so use the search button alot and you should have almost all of your questions already answered but if you cant find it most likely if you post the question here someone will provide a very helpful answer in a short amount of time.
Welcome to the forums :D
Hi i'm Old. Borrowed and Blue should be along shortly. :)
Hints... Charge your battery. Turn it on. Point. Press record.
Other than that help is based on what you need. As SurrealSolutions stated, read and search are your best friends. You can either use the search at the top, which will not get small words or try the following google search...
(sample google search, two is a small word which DVXuser search does not pick up)
:thumbsup:
