Ikonoscop A Cam-Dii
ethereal
http://www.ikonoskop.se/dii/
just wanted everyone's input on this camera... i was looking for a super 16mm on their site, and stumbled across this...
1920x1080 resolution RAW footage from a Super 16mm sized Global Shutter CCD! 1-60 fps, and the camera DOES shoot raw, not TIFF, but its wrapped in a 12bit DNG file...
it accepts PL, Leica M, IMS and C-mount lenses.
its for 7000 euros... basicly around 9,900 USD... if you were to buy an HVX-200A with a 35mm Adapter for example, it'd be more expensive than that... i'm waiting on some footage from the camera, but otherwise, everything looks good.
If it is all that it says it is, i'm buying it... any issues anyone sees?
Full Specs on site:
Image size 1920 x 1080 pixels
Format Individual files in RAW sequences. DNG format
Colour depth 12 bit
File size 3,5 MB/frame in RAW
Sensor CCD: 10,6 mm x 6 mm (Super-16)
Framerate 1 - 60 fps
Sound 2 channel 48 kHz
Timecode 5 pin Lemo SMPTE
Video output Monitor and HDMI
Data output USB 2.0 Power 7,2 V in, or onboard Sony NP-F770
Lens Ikonoskop 9mm f/1.5 cine lens
Body Milled aluminum
Measures 222 mm x 91,5 mm x 83 mm
Lensmount PL, Leica M, IMS and C-mount
Threads 3/8" and 1/4"
Weight Less than 1,5 kg incl. memory cartridge and battery
