IIF ACES workflow used on FX show Justified
I don't understand this at all.
It's basically an intermediate file format where you can take 10bit LOG and expand it into 16bit linear for grading, with the implication that somehow a grading system applying LUTs to 10bit LOG directly in a grading system is somehow broken.
They go onto mention that in this show's particular case that after they take that step, they can then use the Lustre's film based gamma/black point/white point tools instead of a correction software toolset internal to the Lustre that is more for Rec709 material (lift/gamma/gain).
I can understand how using a different set of processing internal to the Lustre could result in a look that somebody likes better, but really isn't saying this process looks better just complaining about a 10bit S-Log to Rec709 LUT that doesn't look nice by default? Maybe akin to some of the bogus decoding of Red R3Ds back in the early days of the Red One?
I thoujght the point of the article was about standards based color management from just about any of the modern cameras. Red, Sony, Alexa....I've read posts by Mike Most over at Reduser about all the different proprietary workflows out there. The IIF ACES standards would help alleviate that. Since OpenEXR is just tha,t open, and supports z depth, and layers... they decided to use that as the basis. The standards can be implemented in any grading software.
From that viewpoint, it makes a little more sense..."here's an extremely capable intermediate format you can cook your Red/S-Log/Log-C footage to, so the colorist has an easier time of things and things might look better along the way too".
I suppose if for some reason all of your online has to go through a DPX step anyways, this is an easy/terrific step forward, but for anybody else...I guess if they just would have had a summary of here's a smart DPX replacement, I wouldn't have had such a strong response. I think maybe I was a little frustrated that it was a SUCH an overcomplicated puff-piece of a read.
