IF box on the top?
You can have it in either position. Main reason for putting it on the top would be to make the camera shorter, I guess.
The only limitation is you can only power the camera via the IF box when it is mounted on the rear of the camera.
I used to have my IF box on the top and my cinedeck mounted on the back, to keep it a bit more "compact".
Does the handle mount back onto the top? I dont understand how the box mounts exactly and how the Vmount mounts on these things.
The IF box and the dock plate/cover have the same screw arrangement and size. The handle or V-mount will screw onto both of them.
