I think it has come to and end.
They no longer show the Shuttles on BM's site. They do have the Intensity Pro 4K PCIE card though. Maybe the Shuttles will get an update at some point. They only do HD and 16 bit audio so kind of obsolete now for anything other than transferring old tapes.
I've just completed a job digitising some 25yr old VHS tapes, and many were totally worn out. I find it weird that Premiere and a decent capture card simply cannot cope with dodgy video. IS there any VHS video that is stable enough?
I discovered a really stable way to do it. I bought a dirt cheap composite to usb converter from ebay and Premiere didn't like it at all. OBS, on the other hand, recorded it totally fine - even the bits when the picture completely vanished!
Back in 2017 I was expecting a 4K Shuttle 2 with Thunderbolt 3 and hardware based TBC to capture old worn out VHS tapes but it never happened.
Premiere Pro works better than any other NLE with 3rd party hardware. I had a cheap USB capture and the quality sucked compared to the ADVC 110 and Intensity Shuttle. That being said could you post a sample clip?
https://youtu.be/dVLUxRkPMdA
https://youtu.be/7R4vVNQsVec
I have one of the last top of the line JVC consumer VHS decks with a built in two line TBC/ frame stabilizer. Works well with the Intensity Shuttle. but nothing will help a tape that has degraded enough to lose its control track. Sometimes fast winding the tape forward to the end then back to the beginning will even out tension enough to make some difference at the margin.
Intensity Shuttle is fine for what it is, but the limitation of 16 bit audio shows its age. Everything else is running at 32 bit float software wise.
I've always used a TBC to stabilize VHS for capture. A while back I did a capture and restoration of one of the few known PAL 50i VHS copies of Dire Straits' very last Brothers In Arms concert performed in Sydney on the 26th of April 1986. A concert that was never officially released on DVD or on CD. The VHS tape was of pretty average quality and suffered very bad wow and flutter due to age, tape stretching and the original very low 1" a second tape speed of VHS. Some luck as the audio was actually in linear stereo. Lucky because back in '86 stereo VHS recorders were like rocking horse manure!
Because of the wow and flutter I processed the audio track in Celemony's Capstan. This was rather tricky as the wow and flutter can be minimized but that involves correcting the speed increases and decreases in the audio file. With a perfect process this in turn changes the length of the audio file relative to the video track. Okay for a standalone audio track if it's a little longer by a few samples or even a second or so but no good at all when it has to be matched with a video track of a certain duration. A video track that has inbuilt timing errors even though its been through a TBC. A TBC restores the frame sync timing and stabilizes each frame content but doesn't correct for overall tape stretch drift. The process was to capture the VHS through a full-frame TBC via the component output of a studio S-VHS player. The captured file was then exported as a stills sequence. This stills sequence was then batch processed in Topaz DeNoise AI. The final remaster was to Cineform at High Level in 4:3 PAL which was matted over a 16:9 Gaussian blur background and then output along with the Capstan "de-wowed" export audio.WAV file. The WAV file has minor pitch changes due to time constant matching to the video track but overall it's is a big improvement over the original rather ropey VHS copy. The end result is a cleaned up SD Widescreen 16:9 file. Not perfect by any means. Still, it gives the concert a new lease of life over the original 4:3 VHS recording. I'm currently in ongoing discussions with Guy Fletcher who was one of the keyboard players on that monumental tour about doing a full restoration and for the record label. With a view to a possible release and an HD AI upscale hopefully. A restored SD sample of track #1 Ride Across the River can be downloaded from here:
EDIT: Forgot to mention that there were some bad dropouts on the tape which were fixed as best as could be done without doing a total rotoscope frame by frame restoration.
https://www.sendspace.com/pro/dl/u6izvn
Chris Young
The capture was from a common or garden PAL 50i VHS output from a Sony S-VHS player and converted to SDI PAL 50i which was recorded as SD 4:3 to ProRes. All the subsequent massaging done after that was round-tripping from Vegas Pro through Topaz DeNoise and back to Vegas Pro then Handbrake for the final MP4. The audio was exported as WAV for wow and flutter processing in Celemony's Capstan then brought back into the timeline for final render out with the vision. Best watched in its native resolution obviously. Widescreen SD.
Because of copyright reasons and ongoing work with others involved, I can't put any of the material up on any social media site. You can download a sample from the link below. Any suggestions or tips on how to improve the process would be welcome. I've already worked out ways of improving things on future recovery work of this nature. Things I would change in the workflow to improve both speed and quality.
Chris Young
Sorry about that. Used an Atomos Samurai recorder via SDI. Then just brought the file into the PC.
Chris Young
