I see ghosts - 720 50p
sasi_yaad
Here are two frames from the same take.
Shutter is 1/50 on a PAL GH1.
Can anyone explain ?
Sassi
What are your project settings?
Do you have disable resample on or off for that clip? See if it the other makes a difference
Is the clip "interpreted" as progressive or interlaced? and do you have "blend" deinterlace turned on or off in the project settings?
Thanks PDR. When I turn on disable resample, the ghosts are gone , so this is not a GH1 issue. Do you know if it can be changed for all new projects ?
not sure if you can ... sorry. I can't find the setting in the preferences to change the default behaviour
you might have to manually do this , or select all clips then disable resample
