Such a thing as you describe does not exist. All mics pick up sound from all directions. Shotguns FAVOUR sounds coming from straight ahead but they aren't completely deaf to sounds from other directions. And to further complicate things, the degree of directivity they exhibit depends on the frequency of the sound itself. 'Gun are designed to be relatively directional at the typical frequencies found in human speach but are less so at frequencies much higher or lower than that. Indeed, in the low bass ranges shotguns become almost omnidirectional. It's all a matter of degree. The closest thing to a mic with the characteristics you want that was produced was a multi-tube mic that used a cluster of interference tubes of varying lengths with a capsule in each one, looking sort of like a small organ ... very directional but also VERY expensive and made in very small numbers, never generally avaiable on the market.I need a shotgun microphone with the absolute best/most narrow pick up pattern straight ahead...absolutely no sound coming from the back or sides...maybe a few options in different price ranges out there?
Thank you.
