I am fairly new with p2 files. I have used it once before and it worked just fine. For some reason I cant seem to import the files into after Effects. It works fine in Premier but when I export to AE the file does not come in. ANy ideas?
Am I doing anything wrong? the format is DVCPRO 720 30P I can import to Premire, but AE doesnt allow it in. I would rather not have to render it out as DVCPRO 720 60P I know that works , but I have hours of footage and that would take a long time. Thanks for the help
would love to find this out as well, have a lot of P2 footage (that works in FCP) but if I want create an AE project using that P2 footage, would I need to put it into FCP and export it there first? Or is there a way you can just import footage to AE? (seems like a lot of hassle if you just have AE and P2 footage :-\ )
MXF files do generaly work in AE they have done in the past. you can import directly to AE or import it via premiere useing dynamic link. For some reason I am getting an error 86:1 (or something similiar) I have found that if I recreate the file structure and move the files to the new folders it seems to solve the problem, at least some of the time. very weird. must be a codec problem of some sorts. no idea what to do
