Samuel H
Major Contributor
I need to know my gear as well as possible, how it works best, how to avoid its downsides.
I got the speedbooster so that my 24mm could be a real wide angle, but then my question was: if I have to take a portrait, should I go for the 90mm f/2.8 on the speedbooster, or for the 50mm f/1.4 on a standard adapter?
Tests here:
http://www.similaar.com/foto/lenstestsff/lenstests_speedbooster.html
My conclusion: the SpeedBooster delivers a small sharpness increase. Plus, the DoF and brightness advantages make it a winner. But it's not as big an improvement as actually going Full Frame.
My 90mm Elmarit with the SpeedBooster is slightly sharper than both the 50mm or the 90mm on APS-C without SpeedBooster. But it is not as sharp as the 90mm on an actual Full Frame. If all I have is the NEX-5N and I have to take a portrait, 90mm+SB is slightly better (sharper in the center, about the same in the corners) than 50mm with the standard adapter. But 90mm on FullFrame would be a lot better.
But the DoF and brightness advantages make the SB even better. I can take that portrait with the following settings:
* APS-C with standard adapter, 50mm lens set at f/2
* APS-C with SpeedBooster, 90mm lens set at f/2.8
With the same ISO and shutter speed, I'll get the same FoV, DoF and exposure in both cases. Now, looking at the tests, it's easy to see which option has the lead: because I can close the lens a bit, the one with the SpeedBooster is sharper both in the center and in the corners! Not as good as actually going Full Frame, but an improvement for sure, with no downsides whatsoever (because I've also checked that bokeh is basically not affected)
Tests here:
