Hyperdeck Shuttle Mounting Plate screws
Gradient
I would like to attach the Hyperdeck shuttle mounting plate to the top handle of the AF100.
After bringing the unit to several stores, none were able to tell me what screw and bolt combination I need.
I have heard of Cold shoe mounts and other methods like that but doubt they will be in store anywhere here.
Can anyone tell me precisely what bolts I would need by name and mm if possible so I could pick them up in a hardware store?.
Most of the threads are 1/4-20. There is one 1/4-20 and one 3/8-16 helicoiled thread for more rigid mounting. There are also #10-32 threads on the edge which line up perfectly with the Berkey System lightweight rail block. (That's how I mount mine on rails). There are also threaded holes to mount IDX or AB battery plates directly.
The threads on the top of the handle on the AF 100 are 1/4-20 and 3/8-16
Hope this helps
Hope this helps
Thanks for that. I will have a look for those tomorrow.
Hi,
I manufacture a device called a Stud Mount, a short piece of 5/8" aluminum rod threaded at both ends 1/4" X 20. On one end it has a hard plastic knurled knob to position what ever you mount on it. It was made to accommodate small monitors but it will also hold your HyperDeck Shuttle with the controls facing the operator side of your AF100.
If you would like a photograph and more information about this and other mounting products, email me at vardalos@horizoneastproductions.com
Phil Vardalos
