The steps were taken from the Service Manual for the HVX200P/202EN etc... The real service centre CD-ROM has a power-point like presentation of what steps to take to un-build the HVX camera. SM stands for Service Manual.
*** ALL PHOTOS HERE and Additional ones Are Also Available in 12megapixels on FLIKR ***
For now I'm going to step 4 which is to remove the LCD/button assembly. Do not do this if not electronically inclined or with improper tools. Not my fault if you void warranty or break your camera. For informational purposes only.
PRIOR TO DOING ANY OF THIS, REMOVE the Battery and Any P2 cards from the camera, also open the TAPE compartment, (no need to have the DV in the EJECT position).
Removal of Backplate (6) 4mm philips screws
HVX with Backplate removed - The blue wires connect power to the cam from Battery.
You will see access to 3 4mm black screws that will be needed to remove LCD/buttons assembly.
Below are some odd connectors that are not in the SM, may be optional or for additional DIAG. SM only uses the one behind the battery bay. If anyone knows what they are for, please share.
Next I removed the plastic plate that covers the Zoom Lever, Rec Check and Eject Button. This is needed to gain access to two more screws holding the LCD assembly.
The tricky part is the Last Screw holding this plastic is right under the blue eject button, if you don't have it out, you may feel the need to pry on the plastic, DON'T. Everything comes apart with zero to minimal force. Open the tape bay.
Remove the screw right below the blue eject.
Removing 6 more screws ( 2 at the 3CCD sign, and 3 more you can see in this photo, allows you to take this plastic cover off, no force is needed unless you spilled a coke/sugar drink on your CAM.)
This is what the camera looks like with that plate removed. You can now see a orange ribbon cable (and you can see access to the XLR Jack panel and Component/Composite Input Panels. (but more on that later).
Now to Step 3 - Swinging open the LCD display will expose a screw right about the BARS and Reset buttons. It is one of the 7 screws holding the LCD/Buttons panel
Here are two more screws holding that assembly.
Here is one more on top right side with LCD panel closed.
Here are 3 more on the bottom of the CAM holding the LCD/Buttons
Here they are removed.
If you've done everything right, the display assembly will come off WITHOUT FORCE.
Be very slow and very careful taking it off, as there is a ribbon cable plugged into it, connecting it to the cam, do it on a surface that will not let it hang by its own weight.
Included is a larger picture to illustrate. Once again if you break your CAM I'm not responsible.
This is what the LCD/Buttons assembly looks like laying on the side. The cable unplugs from This Assembly not the CAMERA. Do not pull on this cable.
By pulling (with your fingernail or a plastic wedge, NO not with a screwdriver) on the little brown notches on this connector (from both sides one at a time) you can unlock the ribbon/flat cable holding the LCD/Buttons assembly onto the CAM, I used my fingernail. Do not just pull out the cable, if its not free to move, you're not doing it right.
At this point. You have 3 modules removed from the Camera and your LCD/Buttons assembly is free to service.
The Part Number of this FPC reads VWJ1845-0 - I think can eliminate it as the culprit behind the MCR/Menu problem.
On the Panasonic Parts List I don't see this cable, however see (4) one matching closely - denoted with asterisk:
WJ10H2065L0 FLEXIBLE CABLE 18.43
VWJ1805 FLEXIBLE CABLE 18.27
VWJ1844 FLEXIBLE CABLE 25.00 **
VWJ24H2060L0 FLEXIBLE CABLE 18.34
The LCD/FStop/Buttons assembly has it's own unbuild instructions, the LCD itself can be removed rather easily and I will include it's un-build in further posts.
Included below are some other cable connectors between main parts of the camera with their model stamps.
Connector from inside the CAM to the TOP-OP CBA
Two connectors from MAIN to P2 or Codec or TOP_OP
Cable A is a 12 pin cable from the BACK CBA (where the MCR button is)
Also there is a bent, white/blue ribbon cable.
Here is another view to orient it
Here is another shot of the E41447-SH cable for the BACK CBA
Here is also a shot of the 5 pin connector from the BACK CBA to the camera body, that you need to be careful with, in its placement.
I need help Identifying the FPC cable responsible for the MCR/Menu button dysfunction.
Next steps in disassembly will include removing the EVF/View Finder, Handle Bar, And making available the TOP-OP CBA (MENU Button) and BACK CBA (MCR/Mode Button).
Also the Detailed disassembly of the LCD/Buttons and LCD Replacement Disassembly.
Any information you may have to contribute is appreciated.
Here is a link to all the HI-RES photos on Flikr
http://www.flickr.com/photos/sweetannie4u/sets/72157621318764768/
I've since re-assembled the camera into a complete state, this operation takes about 5 minutes to do total, and 15 minutes to test. (Your milage may vary.)
Tools needed - a good, small phillips screwdriver (no not from RadioShack) think Sears Hardware.
Photos are released under the Creative Commons Attribution-Noncommercial-Share Alike 3.0 United States License
[URL="http://creativecommons.org/licenses/by-nc-sa/3.0/us/]
[/URL]
